Hi Tapio,
I don't understand why doesn't the external Trigger work for you?
RegardsTK
Message: 7372 |
Date: 4/29/2013 |
Subject: Re: Mach3 external reset similas to external cycle start? |
Mach did get upset having EStop and OEM trigger tied to same pin.
I think I have to do this in the WatchEnable loop:
Read bit-> if Estop cleared, wait ~0.5sec, send message to Mach saying reset is pressed.
Open quetion for me is How?
Rgds,
Tapio
> Hi Tapio,
> From: tapiolarikka <tapio.larikka@...>
> Sent: Sunday, April 28, 2013 11:04 AM
> Subject: [DynoMotion] Mach3 external reset similas to external cycle start?
> Hi!
> I noticed that in plugin config there is a possibility to specify a external cycle start bit/button.
> Can this be handled in the init thread?
> If Yes then is there a way to do the Reset button the same way?
> I tried the OEMTrigger/HotKey but that doesn't work since I need to read this from the state of the EStop Bit.
> My control voltage circuit is set up so that releasing the estop switch does not turn the voltage on.
> Control voltage is activated with separate button so I think it is possible/safe to do this if possible.
> Rgds,
> Tapio
Message: 7382 |
Date: 4/29/2013 |
Hi Tapio,
It still isn't completely clear to me what you are trying to do. But attached is a program to watch an input, detect a change, delay, set another virtual bit. maybe that will do what you desire.
To test I used the KFLOP Led's
HTH Regards TK
